14 years ago
Connection between Hardware and NIOS II (Bridges, Streaming)
Hello!
I am searching for a fast method to transfer data produced in the Verilog hardware to the NIOS II processor. My ideas are:
  • Using Avalon-MM Slave and Avalon-MM Master in the SOPC builder, but I don't know how they work; I can't even find the Avalon-MM Slave in SOPC builder :(
  • Filling the SRAM with bits (controlled by the Hardware) then transfer the SRAM control to the NIOS II, maybe through a tri-state-bridge or high z-states??
What is the best method to transfer data between hardware and the processor?
Best would be if 32 bit words could be transferred at 50 MHz.
Why I want to do that:
I need to transfer data produced at constant rate by the Verilog hardware to my computer. I already managed to send something via NIOS II+Ethernet to my computer. So the next step is to get the data from the Hardware into the NIOS II.
I am using the DE2-115 and the DE4 board and I want to transfer 1Gbit of data at a time.
Thank you!
    Thanks! I need to learn how to do that, but looks complicated at first glance.
    For now, I use PIO registers and a hardware buffer, which can be read at approximately 5MHz.
    Cheers
    You need to put your verilog code into a custom SOPC component, that provides the data through a standard Avalon Stream Source interface.
    Thank you, direct memory access is definitely what I need!
    I instantiated the Scatter-Gather DMA controller in the SOPC builder with the transfer mode "Stream to Memory" and connected the m_write output to the SDRAM and the two descriptor ports to an on chip-memory instance. So, remaining is the port "in" in SOPC builder that I need to connect to an "Avalon-ST source".
    Can you tell me what I need to connect this to in the SOPC builder to have an actual input in my Nios module in the Verilog code?
    SGDMA would be the answer for You, but no chance that Nios will be capable of processing such data rate.
