14 years ago
Connecting two Marvell PHY devices to one Cyclone III FPGA
- We need to send data from one Cyclone III development board to two receivers. One of these receivers is a displaying panel while the other one is sent to another cyclone III development board (that is connected to a displaying panel too).
- This is implemented as shown in the attached image, by branching the required signals like mdio, mdc,data,.. .
When assigning the mdio to two pins one of them is D2 in bank 1 and the other one is the already assigned pin in cyclone III development board (AB2) "PHY not found in PHY profile" error occurred. If changing the pin location to IOBANK_1 , the connection is successfully established & there is no error detected.
Kindly note that this error occurred without connecting the second board?
Can any one help us.
Thanks & Regards
    --- Quote Start ---
    Why do you use two extra pins? Both PHYs can be connected to the same MDC/MDIO lines.
    Anyway I think your problem is with ORing the mdio_in signals. A non driven mdio line will pull to a high level, then the OR gate will always result in receiving all ones.
    Replace OR with AND.
    --- Quote End ---
    Thank you very much for your reply :)
    1- We use extra pins to connect to another PHY that is not existing in Cyclone III development board. These pins are connected to the second designed board via the HSMC connector
    2- Regarding your suggestion we are going to replace the Or gate with an AND one.
    Kind Regards
