15 years ago
Connecting my FPGA to PC
I've just received my FPGA board (It's an Altera Baixun, EP1C6T144C8N) and I can't manage to get Quartus to detect it (when I go in Add hardware..., there is only two options: ByteBlaster and EthernetBlaster). It is linked to my PC with a serial cable.
Thank you.
    I guess, you didn't read the user's manual thoroughly. Quartus doesn't connect to the board through serial interfaces, it uses JTAG interface exclusively for configuration and test. Some boards have an on-board USB-Blaster with an USB connector, but I guess, the said board hasn't. You have to use USB Blaster, Byte Blaster or Ethernet Blaster to connect to the board.
    Thanks for the reply.
    I'm not connecting my board via USB Blaster. I'm using the serial cable at the moment and Quartus doesn't let met click on Auto-detect.
    one advice is you don't want to use Baixun's board.
    less people use it.
    terasic is much more popular and not expensive so much.
    anyway
    I have seen the schematic of your board(maybe).
    just attache your blaster and press AutoDetect button on QuartusII-Programmer software.
    if you can see EP1C6 device?
