15 years agoConnecting my FPGA to PC
Hi, I've just received my FPGA board (It's an Altera Baixun, EP1C6T144C8N) and I can't manage to get Quartus to detect it (when I go in Add hardware..., there is only two options: ByteBlaster a...
15 years agoI guess, you didn't read the user's manual thoroughly. Quartus doesn't connect to the board through serial interfaces, it uses JTAG interface exclusively for configuration and test. Some boards have an on-board USB-Blaster with an USB connector, but I guess, the said board hasn't. You have to use USB Blaster, Byte Blaster or Ethernet Blaster to connect to the board.
