9 years agoConnecting a Graphics LCD to Max10
I am looking to wire up a small 1/4 VGA LCD to my DECA board, I'd like to show some simple graphics (labels, maybe some text boxes, indicators, etc)...No animation or anything like that. I do not w...
9 years agoHI, if full Linux with HD support over HDMI can be run on this board, image processing merging images and videostream from camera why it cannot support it on a smaller TFT with reduced stream speed?
I use TFT on this board, I simply plugged on the 4D model I sent you the link, it work very fine with all my IP cores and NIOS. Can someone can port TFT Linux driver too but this is a time consuming task and I cannot do myself for now. About simple images check what you need and scale IP cores to fit your need. Nothing can be said, you can use a blitter to display block from a flash or compute someting from embedded processor then display dot by dot. Regards
