19 years agoConnecting 3.3V IO to 1.2V for pin compatibility
Hi, I am designing a board containing a CycloneII FPGA. I am not sure which part numer i should to use, 35 or 50. These two parts are pin compatible except that some pins are used as VCCINT(...
19 years agoON the Same Assignments Device page, there is also a box called "Device and Pin Options".
On the Unused Pin Tab - You may need to change the selection from the default of "As output driving Ground" to something like "As input tri-state with weak pull up" so that in the package where the pins are connected to Vccint (1.2v) you do not have an un-used I/O not driving this to ground.
