15 years agoConnect USB Blaster to Altera Live Design Evaluation Board ( LPT )
Hi ! I'm from Poland and I have problem with connect USB Blaster to Evaluation Board. I have Altera Live Design Evaluation Board with ByteBlaster ( Port LPT ). I buy USB Blaster and I do...
14 years agoHi,
Today I got my Terasic USB Blaster cable and I got it working with the LiveDesign board. first, in the USB blaster cable I removed the 10 pin ribbon connector and replaced it with individual flying leads, this is only to make it easier to connect each pin to the board. Then I connect: USB Blaster (10 pin) -> LiveDesign (J1C 26pin) 1 TCK ------------------> 2 2 GND ------------------> 25 (you can use any pin from 25 to 18) 3 TDO ------------------> 11 4 VCC ------------------> 3.3V located at JP2 5 TMS ------------------> 3 9 TDI ------------------> 8 Note that pin 4 (VCC) is connected to a different header because the J1C connector doesn't provide 3.3v. Now, this works perfectly with Quartus II ver. 9.1. I use windows 7 64 bits. However when using latest Quartus ver 11 then sometimes it detects the cable, sometimes it doesn't. I can't understand why. But 9.1 works flawlessly. I already tested several projects and they all load ok. I use LiveDesign board with Cyclone I FPGA. For the drivers, I just use the ones that come with Quartus under ...\Altera\11.0\quartus\drivers\usb-blaster Good luck to all e.
