15 years agoConnect USB Blaster to Altera Live Design Evaluation Board ( LPT )
Hi ! I'm from Poland and I have problem with connect USB Blaster to Evaluation Board. I have Altera Live Design Evaluation Board with ByteBlaster ( Port LPT ). I buy USB Blaster and I do...
14 years agoGoogling for "Altera Live Design Evaluation Board" shows an Altium kit.
Could you post the schematic. From the ones I found, it looks like they only have a parallel port connector, rather than the recommended 10-pin header. You can make an adapter to take the TCK/TMS/TDI/TDO signals between a 10-pin socket and a DB25. You'll also need a ground, and a power signal for the buffer inside the USB-Blaster. You'll want to connect to the PP_HARD_Txx signals. For the power, use one of the other data signals that are pulled up to VCC. The USB-Blaster buffers won't draw much power. Send a complaint to Altium. Perhaps they have an adapter cable. Cheers, Dave
