14 years agoConnect Cyclone II Board to Oscilloscope
Hi every one, I have just did a PWM project with Cyclone II DE1. The Output is a LED. I want see the Waveform in Oscilloscope. How can I do that? How can I connect the LED as output to Oscilloscope t...
14 years agoDear Dave, I am completely new in FPGA, and I don't know the VHDL as well, Could you please help me to change the parts as you mentioned and revise the code.
This is the code, actually I got if from this website. You can see the reaction of the board after compiling: http://www.kiranjose.com/blog/2011/09/pwm-control-in-vhdl-using-altera-de1-cycloneii-development-doard/ I want see the waveform in oscilloscope. Thank you in Advance for your great help. --- Quote Start --- -- Quartus II VHDL Program -- PWM Control -- Author Kiran Jose -- Web: www.kiranjose.com library ieee; use ieee.std_logic_1164.all; entity pwm is port ( clk : in std_logic; pwm_out : buffer std_logic ); end entity; architecture rtl of pwm is begin process (clk) --variable to count the clock pulse variable count : integer range 0 to 50000; --variable to change duty cycle of the pulse variable duty_cycle : integer range 0 to 50000; --variable to determine whether to increse or decrese the dutycycle variable flag : integer range 0 to 1; begin if (rising_edge(clk)) then --increasing the count for each clock cycle count:= count+1; --setting output to logic 1 when count reach duty cycle value --output stays at logic 1 @ duty_cycle <= count <=50000 if (count = duty_cycle) then pwm_out <= '1'; end if; --setting output to logic 0 when count reach 50000 --output stays at logic 0 @ 50000,0 <= count <= duty_cycle if (count = 50000) then pwm_out <= '0'; count:= 0; --after each complete pulse the duty cycle varies if(flag = 0) then duty_cycle:= duty_cycle+50; else duty_cycle:= duty_cycle-50; end if; -- flag changes when duty_cycle reaches max and min value if(duty_cycle = 50000) then flag:= 1; elsif(duty_cycle = 0) then flag:= 0; end if; end if; end if; end process; end rtl; --- Quote End ---
