Confirmation Required: DDR4 HPS EMIF Supported I/O Standards – Agilex 5
Dear Intel FPGA Support Team,
We are designing a DDR4 memory interface using the HPS Hard IP of the Intel Agilex 5 FPGA.
Design details:
- FPGA: Agilex 5 – A5ED065BB32AI4S
- DDR4 Memory: IM8G16D4GBBG-062I
- Interface: HPS DDR4 EMIF
We would like to clarify the supported I/O standards for all signals of the HPS DDR4 interface.
According to the DDR4 memory specifications, POD12 and SSTL12 signaling standards are used for different signal groups. However, in the Agilex 5 HPS Hard IP documentation, we could find SSTL I/O standards listed but could not identify explicit confirmation of POD12 support.
Could you please confirm the supported I/O standard for each of the following DDR4 signal groups?
- Data signals: DQ
- Data strobe signals: DQS / DQS#
- Data mask / data bus inversion: DM / DBI
- Address signals: A0–A17
- Bank address signals: BA / BG
- Command signals: ACT_n, RAS_n, CAS_n, WE_n
- Control signals: CS_n, CKE, ODT, RESET_n
- Clock signals: CK / CK#
Additionally, please clarify:
- Is POD12 supported for DQ, DQS and DM/DBI signals in the Agilex 5 HPS DDR4 EMIF?
- Are SSTL12 standards required for address, command, control and clock signals?
- Are there any restrictions or differences in I/O standards between the HPS DDR4 interface and the FPGA fabric DDR4 EMIF?
- Could you provide the relevant pin-level I/O standard support table or documentation reference?
We require this confirmation to finalize our DDR4 schematic, PCB layout and signal integrity constraints.
Thank you for your support.
Jay Krishna
1 Reply
- ai_responder
Community Manager
Good question, Jay Krishna. Here's a consolidated answer for the A5ED065BB32AI4S.
Critical architectural clarification first: The HPS external memory interface uses I/O pins located in the HSIO bank instead of the HPS I/O bank. Table 21. Input Standards Groups Per I/O Lane — General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs So your DDR4 signal questions all apply to the HSIO bank I/O standards, not the HPS I/O bank (which is 1.8 V LVCMOS only).
Supported I/O standards on HSIO banks for DDR4:
POD12 is a supported HSIO bank I/O standard with VCCIO_PIO = 1.2 V and is specified per JEDEC standard JESD79-4B (DDR4). Table 2. HSIO Bank Supported I/O Standards This table lists the input and output voltages of a HSI — General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs The full set of single-ended and pseudo-differential voltage-referenced standards available on Agilex 5 HSIO banks includes: SSTL-12, HSTL-12, HSUL-12, POD12, POD11, LVSTL11, LVSTL105, and LVSTL700. 2. Device Migration Considerations > 2.8. I/O Interfaces > 2.8.1. HSIO Bank > Table 15. I/O Types and Standards Comparison — Cyclone V to Agilex™ 5 Device Migration Guide
For DDR4 specifically (JESD79-4B), POD12 is the applicable standard across signal groups:
- DQ, DQS/DQS#, DM/DBI: DQS and DQ pins are bidirectional signals driving the dedicated DQS phase shift circuitry. The supported I/O standards for these pins on Agilex 5 include: POD 1.2-V, SSTL 1.2-V, POD 1.1-V, LVSTL 1.1-V, LVSTL 1.05-V, and LVSTL700. Table 5. External Memory Interface Pins — Pin Connection Guidelines For DDR4, POD12 is the JEDEC-standard choice. For Agilex 5 interfaces, the DM/DBI pins do not need to be paired with a DQ pin. 6.3.3.9. Data, Data Strobes, DM/DBI, and Optional ECC Signals — External Memory Interfaces (EMIF) IP User Guide Agilex™ 5 FPGAs and SoCs
- Address, command, control, clock signals: These also reside in the HSIO bank and use POD12 per the DDR4 JEDEC specification (JESD79-4B). Agilex 5 FPGA DDR4 IP supports fixed address and command pin placement, and fixed data lanes placement. 6.3.3. Pin Placements for Agilex 5 FPGA DDR4 EMIF IP — External Memory Interfaces (EMIF) IP User Guide Agilex™ 5 FPGAs and SoCs SSTL-12 is available on HSIO banks and was common for DDR3; for DDR4, the EMIF IP will assign POD12 to these pins.
On-Chip Termination (OCT) for POD12: For POD12, RS OCT (series termination) is available without calibration at 34 Ω or 40 Ω, and with calibration at 34 Ω or 40 Ω. Table 12. Selectable I/O Standards for R OCT for HSIO Banks S The default values are in bold font. — General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs For POD12, RT OCT (parallel termination) without calibration is 50 Ω, and with calibration is 40 Ω, 50 Ω, or 60 Ω. Table 14. Selectable I/O Standards for R OCT with Calibration T This table lists the output termina — General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs Calibration accuracy for POD12 (and SSTL-12, HSTL-12, HSUL-12) with the 34 Ω and 40 Ω RS setting is 20%. Table 19. HSIO OCT Calibration Accuracy Specifications — Agilex™ 5 FPGAs and SoCs Device Data Sheet
External termination scheme: POD12 requires single-ended POD I/O standard termination. Table 16. I/O Standards Required External Termination — General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs Differential POD12 requires differential POD I/O standard termination. Table 16. I/O Standards Required External Termination — General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs
HPS EMIF vs. Fabric EMIF differences for your device (E-Series Group B):
Both use HSIO bank pins with the same I/O standards (POD12 for DDR4). The key differences are:
- For E-Series Device Group B, the fabric hard memory controller supports DDR4 SDRAM at a maximum frequency of 1,200 MHz. Table 69. E-Series Device Group B FPGAs Memory Standards Supported — Agilex™ 5 FPGAs and SoCs Device Data Sheet
- For E-Series Device Group B, the HPS hard memory controller supports DDR4 SDRAM at a maximum frequency of 1,066 MHz. Table 69. E-Series Device Group B FPGAs Memory Standards Supported For specification status, see th — Agilex® 5 FPGAs and SoCs Device Data Sheet
- E-Series devices support only component interfaces; they do not support DIMMs. 3.1. Agilex 5 EMIF Architecture: Protocol and Maximum Interface Width Support — External Memory Interfaces (EMIF) IP User Guide Agilex™ 5 FPGAs and SoCs
For your schematic and PCB design, set VCCIO_PIO = 1.2 V on the HSIO banks used by the HPS DDR4 EMIF. The EMIF IP will auto-assign POD12 to all DDR4 signal groups (DQ, DQS, DM/DBI, address, command, control, and clock), and you do not manually assign I/O standards to individual pins — the IP-generated.qipfile handles all location and I/O standard assignments. EMIF only supports 1.05 V/1.1 V/1.2 V True Differential Signaling for the PLL reference clock; Altera recommends that every EMIF interface have its own PLL reference clock source, and you must use an I/O standard that has the same VCCIO_PIO requirement as the I/O standard used by the EMIF protocol. 4. Design Entry — Device Design Guidelines Agilex™ 5 FPGAs and SoCs
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
