15 years agoConfiguring from Numonyx M25PX16 (2.5 V)
I have been able to configure an EP4CGX15 from the M25PX16, but I have to use "Convert Programming Files" and check the "Disable EPCS ID check" box as the device ID is different. The problem is...
15 years agoI didn't use the disable ID check option, so I can't say, if it actually works. But it can be set in the conversion setup and thus should expected to be used also in an automated batch conversion.
The compression point is somewhat tricky, it has to be set in the properties of the respective input file. The compression status of the input file doesn't count, it's compressed respectively uncompressed anew. (It's a serial topic in Altera forum...)
