15 years agoConfiguring from Numonyx M25PX16 (2.5 V)
I have been able to configure an EP4CGX15 from the M25PX16, but I have to use "Convert Programming Files" and check the "Disable EPCS ID check" box as the device ID is different. The problem is...
15 years ago --- Quote Start --- The problem is that I don't see a way to disable the ID check and still be able to use a compressed bitstream and a user configuration clock. Any workarounds? --- Quote End --- I don't exactly understand where using quartus_cpf conflicts with the compression option and a user clock?
