8 years agoConfiguring FPGA from HPS on SoCKit board
Hi everybody!
I'v managed to boot Linux from QSPI-flash on SoCKit board, but I can't configure FPGA from QSPI-flash. I'm trying to configure FPGA from preloader as shown in GSRD v13.1- Programming FPGA from HPS. I created 3 partitions for QSPI and wrote fpga.rbf file into /dev/mtd2, rebuilt preloader (after making changes in socfpga_common.h file) and flash it into /dev/mtd1. After powering the board I got U-Boot SPL 2013.01.01 (Apr 10 2018 - 11:59:25) BOARD : Altera SOCFPGA Cyclone V Board CLOCK: EOSC1 clock 25000 KHz CLOCK: EOSC2 clock 25000 KHz CLOCK: F2S_SDR_REF clock 0 KHz CLOCK: F2S_PER_REF clock 0 KHz CLOCK: MPU clock 925 MHz CLOCK: DDR clock 400 MHz CLOCK: UART clock 100000 KHz CLOCK: MMC clock 50000 KHz CLOCK: QSPI clock 370000 KHz RESET: COLD INFO : Watchdog enabled SDRAM: Initializing MMR registers SDRAM: Calibrating PHY SEQ.C: Preparing to start memory calibration SEQ.C: CALIBRATION PASSED SDRAM: 1024 MiB FPGA : Programming FPGA SF: Read data capture delay calibrated to 3 (0 - 7) SF: Detected N25Q512 with page size 65536, total: 67108864 into the Linux console... I've tried MSEL="00000" and "01010", but without any success. Bootsel = "111" (boot from QSPI). If I change the preloader to another one (without FPGA from QSPI configuring support) Linux normally starts from QSPI... Any help will be appreciated.No RepliesBe the first to reply
