14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- So now the write is working properly. --- Quote End --- Great! However, make sure you follow Frank's and my advice; keep chip-select deasserted until your board powers up, to ensure the SPI device is initialized correctly. If you are developing a robust product, then you want to make sure that there are no 'hidden' issues that will show up in the future. Cheers, Dave
