14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- Even though the ADC has a mode where chip-select can be asserted low all the time, it might need it to be deasserted while being powered up. --- Quote End --- Yes, the chip misses a means to reset the SPI protocol without deasserting CS. I don't see a reliable way to operate the device without connecting CS.
