14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- Yes I can control the chip select. I'll certainly give that a try, set CS high during power up and then set it low after a few clock cycles. --- Quote End --- Sounds like a good debug plan. --- Quote Start --- What bothers me is I never fail to read the correct default value of a register. --- Quote End --- Never try to interpret patterns, you'll never figure them out. --- Quote Start --- For now I have to change the address value in my VHDL code, re-compile the code, and re-program the FPGA. I would think a read would be more difficult to accomplish since the SDIO line has to change from an input to an output whereas for a write, it stays as an input line. --- Quote End --- You need to write an ADC interface controller, wrap it with a Avalon-MM registers interface, drop it into an SOPC or Qsys system, and then debug. That way you can generate reads or writes to whatever addresses you like. It may seem like a lot of extra work up front, but you'll benefit from it in the long run. Go through this tutorial: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave
