14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- All the registers in the memory map table (pg. 27) have 8-bit data. --- Quote End --- Ok. --- Quote Start --- For now I'm only trying to perform one transaction. I either do a read or a write. For a read, I send 16-bits to the ADC (1-bit R/W + W[1:0] + Addr[12:0]) and get 8-bits back. For a write I just add 8-bits of data after the address. --- Quote End --- Right, but its not working. So as a debugging aid, can you control the chip select signal? When your board powers on, what is to stop a few glitches occurring on the clock signal and getting the device in a screwy state. Even though the ADC has a mode where chip-select can be asserted low all the time, it might need it to be deasserted while being powered up. Just a thought ... Cheers, Dave
