14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- I didn't read the data sheet completely. Take a look and see if there is a requirement to write a specific number of bytes, eg., write access to 16-bit register X must use 2-bytes otherwise write transactions will be ignored. --- Quote End --- All the registers in the memory map table (pg. 27) have 8-bit data. --- Quote Start --- The other thing is that previous transactions may be screwing up the interface. Can you control the chip-select? If you can deassert it, then you can ensure you have reset the ADC internal logic. --- Quote End --- For now I'm only trying to perform one transaction. I either do a read or a write. For a read, I send 16-bits to the ADC (1-bit R/W + W[1:0] + Addr[12:0]) and get 8-bits back. For a write I just add 8-bits of data after the address. --- Quote Start --- Also, do you have an ADC clock? Some devices I have used will not work correctly until you *also* have the ADC clock. --- Quote End --- Yes, the 48 MHz fpga clock is tied to the ADC clock.
