14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- Sorry, I overlooked the fact that it's not in the datasheet. I found it in this application note --- Quote End --- Ok, so that is not the problem. I didn't read the data sheet completely. Take a look and see if there is a requirement to write a specific number of bytes, eg., write access to 16-bit register X must use 2-bytes otherwise write transactions will be ignored. The other thing is that previous transactions may be screwing up the interface. Can you control the chip-select? If you can deassert it, then you can ensure you have reset the ADC internal logic. Also, do you have an ADC clock? Some devices I have used will not work correctly until you *also* have the ADC clock. Cheers, Dave
