14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years agoSorry, I overlooked the fact that it's not in the datasheet. I found it in this application note (pg. 6, table 2). Strange why it's not mentioned in the datasheet.
http://www.analog.com/static/imported-files/application_notes/56755538964965031881813an_877.pdf
