17 years agoConfiguring active serial PROM and CPLD in single JTAG header chain
Dear all, I need to configure both CPLD (EPM570) and active serial PROM (EPCS16) on a single JTAG chain header. Here EPCS16 can be configured via JTAG using the Serial Flash Loader techniq...
17 years agoof course you can
make shure your fpga is the first in the jtag chain, otherwise you must tell all your scripts and tools to use device 2 what is a pain. if the fpga is the first in the row then you just connect the jtag to your pcb and quartus and all others run as there is only one device in my designs i have jtag tdo pin 3 <- MaxII TDO MaxII TDI <- FPGA TDO FPGA TDI <- JTAG tdi pin 9 so your cpld is the first device on jtag chain
