12 years agoConfiguring 2 Cyclone III's from one EPCS16 Using 2.5V
Hello, My FPGA configuration signals an error by pulling the nStatus line down at the end of configuration and starting over (and over and over). 1. I am attempting to configure two EP3C4...
12 years ago --- Quote Start --- I cannot program the two FPGA's separately since I cannot decouple the Config_Done's. --- Quote End --- You misunderstand. The first FPGA *can* be configured by the EPCS device, but it will not enter user mode, since the other device is holding CONF_DONE low. If you use JTAG to program the second device, then it will release CONF_DONE, and both FPGAs should enter user mode. Yeah, its subtle, but it should work. --- Quote Start --- However, if I repeatedly trigger off of nCEO and monitor Config_Done at 10 mV per division and lots of averaging I can tell that the first FPGA must have released its Config_Done right at the time that nCEO goes active (low). Config_Done shows ringing and a 3 mV change in its level. This looks like evidence that it is the second FPGA that is failing its configuration, yes ?? --- Quote End --- Yeah, that sounds like a reasonable assumption. You did not comment yet whether you can program these devices with JTAG. Cheers, Dave
