12 years agoConfiguring 2 Cyclone III's from one EPCS16 Using 2.5V
Hello, My FPGA configuration signals an error by pulling the nStatus line down at the end of configuration and starting over (and over and over). 1. I am attempting to configure two EP3C4...
12 years ago --- Quote Start --- 12. The Config_Done line does not even twitch off of zero Volts. --- Quote End --- If it did, we probably would not be having this conversation :) --- Quote Start --- 13. The nStatus line has a rise time (10% to 90%) of approx. 700 ns, and a fall time of about 1.5 ns. --- Quote End --- To be expected; its driven low, but tri-stated and pulled-up when going high. --- Quote Start --- 14. The INIT_DONE line will go high 448 ns after the nStatus line goes low, and goes low 115 us later, 60 us after nStatus goes high again. --- Quote End --- INIT_DONE is an optional pin, it only has meaning near the end of configuration. Have a look at this doc, it has some INIT_DONE timing examples http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf --- Quote Start --- 15. nStatus goes low 800 ns before nCEO of the Master FPGA goes back high. --- Quote End --- Could you clarify; did nCEO transition from high-to-low, implying that the first FPGA configured ok, and its the second that causes the failure? --- Quote Start --- 16. From estimates made by my PCB CAD program, the delay of DCLK from FPGA to EPCS16 is 0.56 ns plus the translator delay. The delay of DATA_0 from the EPCS16 to the FPGA is 0.47 ns plus the translator delay. the translator delay from the datasheet is 0.15 ns max., but could actually be seen to be 1.5 ns. Round trip clock to data back is then about 1.5 + 1.5 + 0.56 + 0.47 = 4.03 ns. --- Quote End --- So do the math - is there any timing margin for the PS device? Cheers, Dave
