9 years agoConfigure 3.3V outputs on MAX7000
Hi, I want to supply a MAX7000 with 5V and have most of the I/O using TTL inputs & outputs. I also want to have 8 bidirectional pins at 3.3v. I see the option in Quartus to set the ...
9 years agoHi Alex,
thanks a lot for the reply. That info wasn't clear from the datasheet, I was hoping that the VCCIO was segregated between the LABs, rather than a single VCCIO rail. Out of interest, is there another datasheet or product note that describes this better, or did I just misread the info in the MAX7000 datasheet. It looks like I will keep the device at 5v and have an external buffer to do the level shifting for the 8 bit bus regards Dave
