yamasan
1 day agoConfiguration using the MT25QU01GBBB8E12-0SIT
Hello, Figure 127, "Connection Setup for Programming the EPCQ-L Using the AS Interface," in the "Cyclone® 10 GX Core Fabric and General Purpose I/Os Handbook" illustrates a configuration that enable...
umut_arrow
1 hour agoHi,
Yes, you can program the MT25Q via Active Serial programming by selecting EPCQ-L. The only thing I'd check is your Quartus version, because the in the older versions you had to enable MT25Q in quartus.ini to be able to see flash devices with bigger than 256Mbit size in the Convert Programming File tool. KB article below just in case!
https://community.altera.com/kb/knowledge-base/how-do-i-enable-microns-mt25q-device-support-in-replacement-to-end-of-life-eol-e/345149
