open01
4 years agoconfiguration scheme
What is the difference between the Configuration scheme in <Device and Pin Options> and the Mode in <Convert Programming File>?
Thanks for your answers.
NurAiman_M_Intel
4 years agoHi,
.rpd file is use to keep the design only. It does not keep the configuration mode. .rpd file will be different if you use different design.
To see the different when changing configuration mode, you will need to see from .pof file because .pof keep the configuration mode.
Hope this help!
Aiman
open01
4 years agoHi, thank you for your answer,
But I use the same design, just make different choices of mode in the Convert Programming File, then the content of .rpd will be a little different, as shown below,
Isn't this a difference in Configuration mode?
Thank you so much.
