open01
4 years agoconfiguration scheme
What is the difference between the Configuration scheme in <Device and Pin Options> and the Mode in <Convert Programming File>?
Thanks for your answers.
sstrell
4 years agoChoosing the config scheme in Device and Pin options specifies how the programming file will be generated when the Assembler is run from a regular compile. Choosing a different scheme in CPF lets you convert an existing file to a different file format or scheme if needed.
open01
4 years agoHi , thank you for your answer,
I want to describe my question in detail once.
My configuration method is to choose Active Serial Mode.
And when I try to compare the programming files with different options.
I found that no matter how I choose Device and Pin options(Configuration scheme) it doesn't affect the content.
As shown in the picture below,
Thank you
