[Configuration Related] Cyclone III AP Configuration
Dear Host,
I am designing Cyclone III EP3C120 Board. On this board, i am configuring FPGA with AP configuration. In this configuration, i am using Micron P33 Parallel NOR Flash Memory.I will program the configuration through JTAG interfacing. For VCCIO banks 1,6,7 and 8, i will use 3.3V. Please provide additional information, if necessary. Regards, Mohsin Hayat12 Replies
Yes - With Cyclone III, if you configure using AS from a serial FLASH device, you can then access/use that same FLASH device to boot Nios or simply access it from your Nios code.
Cheers, Alex - Altera_Forum
One More Point,sir that i want to discuss wid u regarding FPP Configuration, please refer to the document, "Parallel Flash Loader IP CORE User Guide". In this document, at the page 10, this describe the CFI Flash with CPLD only.I am confuse on this point.Please clear it.
For PS Configuration, please see the page 9-34, "Configuration, Design Security, and Remote System Upgrades in the Cyclone III Device Family" chapter of the handbook Volume 1.
Thanks sir for sharing this point.Its cleared to me regarding AP Configuration.
I have last point about the configuration now. In Passive Serial Configuration, Is it possible to use supported flash memories with NIOS II Processor? If possible then ...we connect flash to dedicated pins of FPGA r any I/Os can be used? - Altera_Forum
Providing you follow the guidelines in the "AP Configuration (Supported Flash Memories)" section - page 9-23 - of the "configuration, design security, and remote system upgrades in the cyclone iii device family (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyc3/cyc3_ciii51016.pdf)" chapter of the handbook Volume 1, specifically Figure 9-8, you will be able to use that parallel FLASH device with your Nios II processor.
Dear Host,
Please respond on my query urgently. i am stuck on this point. - Altera_Forum
yes its in Cyclone III handbook but in detail in "Altera Configuration Handbook , Volume 1 & 2".
That should be Cyclone III handbook right?
Oh realli? Please give me Altera Reference Or Any design example? i m realli worried about that. I study alot of time the Altera Configuration Book, volume 1 and 2.But i cann't find. Please give me design example.
Yes. You can use the same parallel FLASH device to both boot your device and then run your Nios from. You don't need a CPLD.
Cheers, Alex
