17 years ago
Configuration flash size for Cyclone III
I'm designing a board with a Cyclone III on it and a microcontroller.
I need some guidelines on different ways of booting the Cyclone III and how big the flash needs to be. The Cyclone III comes in various sizes, how big of a flash would each model need for a full configuration?
I had previously considered storing the FPGA configuration on the microcontroller for ease of upgrades but I have a feeling I'm running out of flash on the microcontroller. I still need to implement a way of upgrading the FPGA config through the microcontroller using an ethernet loader.
    In Stratix the POR duration depends on PORSEL pin.
    if LOW => 100msec
    if high => 12 msec
    same applies to the config device but:
    if LOW => 100msec
    if high => 2 msec
    It is recommended:
    12 msec for stratix, 100msec for config device to make sure who is ready first.
    As to power consumption difference, I am sure it is trivial.
    For config data size:
    You may consider the size of your largesst future device in case you decide to upgrade
    Bringing this thread back to life. Looking at that document and trying to estimate the configuration time. I intend to use an EP3C16 device in a n EQFP144 package and the image size is 4.1Mbit according to the document.
    However I'm not sure what kind of start-up time I can expect. The configuration time would be between 205ms and 103ms according to the manual but as far as I understand, that does not include the time it takes the device to power up (POR time). I'm a bit confused as to what exactly it means to switch between a standard or a fast POR time, what exactly I need to do in my circuit design to support a fast POR time, I understand there is a power requirement difference.
