11 years agoConfiguration file size
hey, what should be a typical size of a configuration file (I means to the size it use in the flash, in order to decide what flash size should I use and if I can put more than one configuration fi...
10 years agoJust FYI, for V series onwards, the file size are documented in datasheet.for older device they are in configuration chapter.
