11 years agoConfiguration file size
hey, what should be a typical size of a configuration file (I means to the size it use in the flash, in order to decide what flash size should I use and if I can put more than one configuration fi...
11 years agoIt does depend on the device. You will have to check in the datasheet to see how large the configuration file will be. The configuration file size does not change with utilization.
Thanks /Boris
