14 years agoconfiguration device
Hello. I am new to FPFA world and i am trying to understand whats is AP mode and AS mode in cyclone4 ? How i set this mode with hardware or software and witch mode i will need for ...
14 years agoYou can always combine JTAG with any other configuration method. Just connect your configuration device to the correct dedicated pins, and configure the MSEL pins for that configuration scheme. IF you use the JTAG pins at the same time then JTAG will take priority and will let you configure and communicate with the FPGA.
