14 years agoconfiguration device
Hello. I am new to FPFA world and i am trying to understand whats is AP mode and AS mode in cyclone4 ? How i set this mode with hardware or software and witch mode i will need for ...
14 years agoAS and AP mode refer to the type of flash device used for configuration. As the FPGA has only SRAM, you need a flash to store it's configuration, that will be downloaded during power up. AP refers to a parallel flash and AS to a serial one. AP mode is faster but requires more pins from the FPGA. IF you also use the flash from software, both type can also be used. With a parallel Flash you can execute the code directly from the flash, whereas with a serial one you need a bootloader that will copy the application into RAM.
