Config pins as normal IO pins
- 4 years ago
Well, for reference I have about two dozen Altera FPGA production designs I have done over that last two decades, and never have I reused the configuration/status pins as normal I/O, or the JTAG pins either. They are all dedicated to their specific functions. If I needed more I/O, I went to either a larger package with more I/O capability, or found some way to multiplex existing I/Os (like using an external 8bit shift register device as an I/O expander, for example). Again just my 2c.
The 'normal' use of those pins is to have 10K pullups on them to VCCIO for their bank.
Figure 10 in section 2.3.1 shows the flow on how pins nCONFIG, nSTATUS, CONF_DONE are used during initialization.
You can't change that, this is BEFORE your internal POF image is programmed into the device.
Other I/O pins are all tristated.
When CONF_DONE transitions from being internally driven low to be pulled high, then the device is done being initialized.
Until this time, you CANNOT drive signals onto those three configuration lines, and you have to accept their levels.
Personally, I think it is VERY BAD practice to use those three lines as user programmable I/O. You will regret it.
Same for the four JTAG lines. Save them for jTAG access programming / debug. You won't regret it.
If you really need 7 more I/Os, use a bigger device, or figure out how to multiplex some of the regular I/Os to expand capability.
Just my 2c.
Ok, this shouldn't be a problem, I wouldn't use those pins before device initialization. (But I don't think anything can be done before or during initialization)
Okay, but if they say it's possible to do it, why should that be a bad idea? I'm afraid that no one has ever actually tried it.
I thought about it, but I should switch to a 256pins device, with increased complexity even in the PCB.
If it is possible to do this with the current device, why not do it?
As I wrote before, I'm afraid that what you read in the documentation has never been tried by anyone or is it really a bad idea to do it, as you told me. For this I am looking for concrete solutions that have already been tested, I do not trust the documentation (however rigorous it may be), but I would like some example circuits that have already been tested.
