8 years agoConfig Flash EPCQ4A Cylone II
Hello there I want to replace the configflash EPCS4SI8N with the EPCQ4ASI8A. The flash is used to configure a Cyclone II chip. In the product discontinuance notification is written, that the ...
8 years agoI can confirm ISSI IS25LQ040B-JNLE
works perfectly as replacement for M25P04 I can program it with version quartus 12.1 SP1 and 17.1 prime without any problem. No 'disable EPCS ID check' or anything else need to be configured. It is recongized as a standard EPCQ4 flash. device ID=0x12 It's a much cheaper solution.
