17 years agoConfig Done Fails to Go high with simple SOF file(Jtag+USB Blaster)
Hello All, Finlay we have got our boards and started testing them out... We were able to successfully Detect the Cyclone 3 120 chip and run Jtag Debug tests, but not been able to configure the ...
17 years ago --- Quote Start --- We are using the Combined Jtage/AS config setup --- Quote End --- The reported situation isn't completely clear to me. You should tell, what's the exact hardware configuration, e.g. referring to an Altera schematic. In some situations, it's necessary to deactivate the on-chip configuration controller to assure, that the JTAG configuration isn't disturbed by tries to load an AS configuration. It's a Quartus Programmer option, that should be selected. If basic JTAG configuration still fails (config done fail), it's most likely a hardware problem.
