14 years agoConfig compression makes no difference
I ran my Cyclone 3 design with and without compressed config file generation & in both cases the .sof file came out to be 350KB. No change with compression. Did I miss some Quartus setti...
13 years ago --- Quote Start --- In my calculation, an EPCS4 image (4 MBit) has a size of 512 kB. The *.pof or *.jic file, although using compression, will be filled up with 0xff up to the image size. ' --- Quote End --- How much time will it take to load the content of EPCS4 into FPGA if payload is only ~2Mbit and the rest is filled up with 0xff ? The case is that EP4CGX22 is in "40 Mhz internal oscillator mode". There are to possible versions: 1). 4,000,000 bits x 25 ns / 1 bit = 100 ms 2). ~2,000,000 bits x 25 ns / 1 bit = ~50 ms 25 ns = 1/40MHz. Which one is correct? P.S. How to calculate decompression time by EP4CGX22?
