14 years agoConfig compression makes no difference
I ran my Cyclone 3 design with and without compressed config file generation & in both cases the .sof file came out to be 350KB. No change with compression. Did I miss some Quartus setti...
13 years ago --- Quote Start --- is going to be the Cyclone 4 GX using the epcs4 flash. If I can't get compression to work, I'll have to move up to the next larger EPCS chip. --- Quote End --- --- Quote Start --- it looks like that device will fit in an epc4 without compression, but you could use compression to make some additional space for user data --- Quote End --- Are You talking about EPCS4 or EPC4?
