14 years agoConfig compression makes no difference
I ran my Cyclone 3 design with and without compressed config file generation & in both cases the .sof file came out to be 350KB. No change with compression. Did I miss some Quartus setti...
14 years agoit looks like that device will fit in an EPC4 without compression, but you could use compression to make some additional space for user data
take a look at the generated .map file before and after compression, you can see the end address change
