mfransson's avatar
mfransson
5 years ago
CONF_DONE remains high during reconfiguration (Arria 10)
We're experiencing an issue with Arria 10 where we can't reconfigure the device without power cycling. We're using passive serial single-device configuration and initial configuration always works.
However, on a configured device, when we pulse nCONFIG, nSTATUS goes low but CONF_DONE remains high. Also, nSTATUS is never released. The device is still operational (i.e. the old configuration is still there).
Looking at the state machine diagram at https://www.intel.com/content/www/us/en/programmable/documentation/sss1412661044400.html I don't see what we're missing. Pulling nCONFIG low should reset the state machine and both nCONFIG and CONF_DONE should go low. The nCONFIG pulse is longer than the 2 us specified in the A10 datasheet (tCFG).
  • We solved it. It turned out that we had chosen DCLK as the clock source for device initialization. Changing this (in our case to CLKUSR) solved the issue.
  • Hi,
    Thank you for sharing the solution with Intel community.
  • mfransson's avatar
    mfransson
  • Hi,
    Does Quartus shows any error code/message? Please provide the screenshot.
    Aiman
