16 years agoCONF_DONE pin not going high when trying to program Cyclone III with an SOF file
I have a problem very much similar to a thread posted some time back but the solution mentioned for that ie connecting nCE pin to ground is not working in my case. Actually nCE is already connected t...
16 years agoYou need to reboot after programing a .jic file.
You can not reboot after programing with a .sof file (the internal SRAM gets cleared). Conf_done only works if activated in the device configuration settings.
