16 years agoConf_done Is Not Going High.
Dear All, We have designed Stratix III(EP3SL340) FPGA development board. With that I am facing strange problem. We are using JTAG interface from Quartus by using USB Blaster to prog...
16 years agoHi Pete,
Thanks for your valuable input..... I will provide few more inputs that will give some additional information on this issue.. There is no change in the design for working & non working sof. The only different is these sof's are generated in different time with same project. Also we have set the the following options in the " Settings--> Device ---> Unused pins will be configured as input tristated." Will this above info gives any clue with respect to the the problems.. Best Regards, Kalidoss
