mgarrison
3 years agoCONF_DONE failure when trying to verify MAX 10 with Encrypted POF
I am using a MAX 10 device and encrypting the bitstream. When creating programming files without "allow encrypted POF only", I can verify the programmed bitstream in the programmer, but when I do se...
NurAiman_M_Intel
3 years agoHi,
I apologize for the late response as I was on emergency leave. I got some feedback from internal team as below;
There is verification issue during programming. Can you used Quartus 21.1standard? Lite version might not have the fix.
Also, can I know if verify is consistent fail or intermittent? What is the failing rate?
Also, please check this out it might help to verify successfully.
Aiman
mgarrison
3 years agoHi, I do not have license for standard. Plus, production uses the standalone programming tool. It needs to work there too.
It consistently fails every time.
I did try programming EKP and POF separately, which did not change the behavior.
