CONF_DONE failure when trying to verify MAX 10 with Encrypted POF
Well, this is interesting. Enabling Real-Time ISP mode does allow it to verify (either with POF or JBC). But, the verify takes 5 minutes to complete! This is unacceptably long for a production environment. Normal verify on POF's for this same device (without verify protect) take about 20 seconds. Do you have any other ideas on how to address this?
Further updates:
- Switching to a USB-Blaster II improves the operation time significantly. It's now down to 15-30 seconds to verify instead of 5 minutes. The 5 minute time was achieved with an original USB-Blaster. 15-30 seconds is fine, but our production programming uses original USB-Blasters currently.
- Running a verify cycle using JBC file with Real-time ISP off does actually work without error, but still takes 5 minutes with original USB-Blaster. It seems you can do verify with POF only in real-time ISP, but with JBC it can be normal ISP or real-time ISP.
- As an aside, when using JBC file, a Program/Configure operation seems to also do a verify right after, though this does not occur when doing POF programming. I see this is part of the JBC file creation settings. (I have never used JBC file prior to now.) Combined JBC program & verify cycle using original USB-Blaster takes over 6 minutes!! Combined JBC cycle with USB-Blaster II is under 2 minutes.
