11 years agocomponents base address and offsets
I know how to get the base address of each component in a NIOS II system "Qsys" or the "system.h" file. What I dont understand is what is the offset and how to get it. for example componen...
11 years agoA memory mapped interface has an address bus, and one or two data buses (read and/or write).
Your component has a 2bit port called 'Address' which I presume is the address line for your Avalon-MM slave. If you are not using the address line, just assume address is 0, so offset will always be 0.
