8 years agoCompiling for EPM7128ATC
I need to compile a design for an EPM7128ATC100. It seems, though, that Altera has tried to erase MAX7000A from history, or something, because according to my own research, the only direct solution i...
8 years ago --- Quote Start --- Sarcasm won't earn you much credibility here... --- Quote End --- I wasn't trying. And FYI : second guessing the word 'need' won't either. --- Quote Start --- No - there's no other way. --- Quote End --- You mean : you don't know of any. Which is fine. But choose your words more carefully. For those looking for the straightforward solution (in the form of old Max+Plus II versions), I just found the older ones (even though Altera does not seem to point to them anywhere on their website) : ftp://ftp.altera.com/outgoing/release/ Among those I tried of that bunch (7.0, 9.0, 9.3, 10.0), the 9.x versions seem to have MAX7000A support (yay). So if you have the same problem, here's a possible solution if you can handle the idiosyncrasies of Max+Plus II, until someone invents some slight tweak for programming files or Quartus device files to retarget them from MAX7000AE or MAX7000S to MAX7000A.
