16 years agoCompilation Broken
Hi everyone,
I'm a CPLD newbie and I'm working in a project using EPM7032LI44-15 CPLDs for my intership.I’m trying to upgrade from CPLD EPM7032LI44-15 to CPLD EPM7064LI44-15 for a project that was dropped for several years. So, prior to moving to the new target, I first tryed build the sources for the old target and realized that the compilation is broken. The only working copy is embedded in an old CPLD EPM7032LI44-15. Is there a way to retrieve the source code directly from the working CPLD EPM7032LI44-15 in order to compare both. Thanks. http://www.alteraforum.com/forum//proweb/misc/progress.gif1 Reply
--- Quote Start --- Hi everyone, I'm a CPLD newbie and I'm working in a project using EPM7032LI44-15 CPLDs for my intership.I’m trying to upgrade from CPLD EPM7032LI44-15 to CPLD EPM7064LI44-15 for a project that was dropped for several years. So, prior to moving to the new target, I first tryed build the sources for the old target and realized that the compilation is broken. The only working copy is embedded in an old CPLD EPM7032LI44-15. Is there a way to retrieve the source code directly from the working CPLD EPM7032LI44-15 in order to compare both. Thanks. http://www.alteraforum.com/forum//proweb/misc/progress.gif --- Quote End --- Hi, it is not possible to retrieve the source code from a programming file. Kind regards GPK
