12 years agoCompatibility of compiled design.
Hi, I want to know if it is possible and save to use a Design compiled for a FPGA with commercial Temperature-Range and lower Speed-Grade in a FPGA with industrial Temperature-Range and lower S...
11 years ago --- Quote Start --- As far as I know, the only differences between the parts are that the I parts passed stricter quality control. They all come from the same wafers. the C parts will have worse timing specs, so something that passes on a C part should be fine on an I part. --- Quote End --- Compilation result is different between a commercial and an industrial Temperature-Range (same Speed-Grade). I had compiled the same design for an EP4CGX50CF23c7 and an EP4CGX50CF23i7. The design compiled for the c part work fine on the i part. But for the same design compiled for the i part, our application showed issues running on target (i part) !! How can you explain this difference ? Thanks Srevault
