12 years agoCompatibility of compiled design.
Hi, I want to know if it is possible and save to use a Design compiled for a FPGA with commercial Temperature-Range and lower Speed-Grade in a FPGA with industrial Temperature-Range and lower S...
12 years agoAs far as I know, the only differences between the parts are that the I parts passed stricter quality control. They all come from the same wafers.
the C parts will have worse timing specs, so something that passes on a C part should be fine on an I part.
