19 years agocommunication ethernet between two FPGAs
Hi to all, I'm a new member of this forum, which, I'm sure, will be very usefull for my problem. So, I'm working with two Cyclon II fpga connected each other by the ethernet cable and I'm tryi...
19 years agoDo you know if the initialization of the Interniche TCP/IP stack dipends
also from the socket management? Differently from the simple socket server example where a connection is establish, I'm tring to use a SOCK_DGRAM communication then I don't manage the structure (called SSSConn) for the connection. What do you think. Thank you.
